Thread: Error |
| Posted on Monday, October 03, 2005 - 06:21 pm: |
When I turn on my car, the CD player gives me an 'Error 03', I have to eject and put the CD back in a few times before it starts working. It annoys me because sometimes it takes forever to get it working. Any reason this could be happening? And it happened out of nowhere too, Ive been using this head-unit for about 3-4 years now, and have never had a problem before. |
Gold Member Username: Illuminator
Post Number: 1898 Registered: Apr-05
| Posted on Monday, October 03, 2005 - 06:31 pm: |
What is the brand and model of the headunit? It sounds like the lens needs to be cleaned... |
| Posted on Tuesday, October 04, 2005 - 09:08 pm: |
Its an Aiwa CDC-X927. How would I go about cleaning the lens? |
Post Number: 1928 Registered: Apr-05
| Posted on Tuesday, October 04, 2005 - 10:56 pm: |
Either buy a CD lens cleaner...or you can open up the unit yourself (hard but cheap way) and clean the lens with a Q-tip that was dipped in rubbing alcohol. |
| Posted on Tuesday, October 04, 2005 - 11:07 pm: |
Ok well Im looking at some Lens Cleaners, and does the quality of it really matter? Would a cheap one fix the problem? The prices dont vary that much, but Im just wondering, since I dont have money to just throw around. |
Post Number: 1931 Registered: Apr-05
| Posted on Wednesday, October 05, 2005 - 02:09 am: |
Nah, it shouldn't matter, and if it doesn't work then you'll be better off from not wasting money on a more expensive lens cleaner. |
| Posted on Wednesday, October 05, 2005 - 02:38 am: |
Alright man thanks for all the help. Much appreciated. |
| Posted on Thursday, October 06, 2005 - 02:52 pm: |
Ok man I got a lens cleaner and cleaned it. Now the CD plays more often althought I do get the "Error 03" still, but it skips on every little bump in the road, or even if I brake at all. What is the problem here, I need a new HU I guess? |
Post Number: 1942 Registered: Apr-05
| Posted on Thursday, October 06, 2005 - 06:28 pm: |
I suppose Error 3 is a mechanical problem, then... I actually have two CDC-X927's that have power supply problems. I wonder if the CD mech from one of them could be used in your unit to repair it. Any thoughts on that? |
| Posted on Thursday, October 06, 2005 - 06:56 pm: |
I dont know if you were asking me, but Im no good at these kind of things, sorry. |
Post Number: 1944 Registered: Apr-05
| Posted on Thursday, October 06, 2005 - 07:11 pm: |
Heh, okay. You might as well check ebay for a new headunit... |
| Posted on Thursday, October 06, 2005 - 07:16 pm: |
Alright man, thanks for all the help anyway. |
