Thread: Subs to go with amp |
dogeatdog Unregistered guest |
| Posted on Monday, April 12, 2004 - 12:35 pm: |
i have a kicker kx series 600 watt mono amp. im looking for a nice set of subs to go with it. Any suggestions? |
NorthWest,
Michigan
Post Number: 1828 Registered: Dec-03
| Posted on Tuesday, April 13, 2004 - 11:53 am: |
any pair of 4 ohm subs rated for ~300-350wRMS each.
NorthWest,
Michigan
Post Number: 1829 Registered: Dec-03
| Posted on Tuesday, April 13, 2004 - 11:54 am: |
Kicker CompVR are a good match
| Posted on Tuesday, April 13, 2004 - 12:32 pm: |
so if i were to go for the compvr subs..which ones should i get. Kicker Comp VR 03CVR104 10" Dual 4-Ohm Voice Coil Component Sub 10" Component Subwoofers or Kicker Comp VR 03CVR102 10" Dual 2-Ohm Voice Coil Component Sub 10" Component Subwoofers..thx
NorthWest,
Michigan
Post Number: 1840 Registered: Dec-03
| Posted on Tuesday, April 13, 2004 - 04:19 pm: |
for two subs, you'd want the dual 2 Ohm coil models. wiring the coils in series will give you two 4 Ohm subs.
| Posted on Tuesday, April 13, 2004 - 04:54 pm: |
ok.. ill get the 2 ohm subs. now you said "wiring the coils in series" how would i go about doing that. |
NorthWest,
Michigan
Post Number: 1847 Registered: Dec-03
| Posted on Tuesday, April 13, 2004 - 08:15 pm: |
New member Username: 92ludedude
Houston,
TX
Post Number: 3 Registered: Apr-04
| Posted on Wednesday, April 14, 2004 - 03:43 pm: |
ok so am I just stupid for wanting to have my subs work not as one but in Stereo? And in order to get a DVC 4 ohm 150rms per coil to run correct in stereo I'll need a 4ch 600W amp or just get the single cone subs and use a 2ch amp 600W amp. Or say screw the Stereo subs and get a mono 600W |
| Posted on Wednesday, April 14, 2004 - 08:20 pm: |
ok... one more thing. what kind of enclosure should i get. i want the bass to sound good, not just be really loud. |
NorthWest,
Michigan
Post Number: 1883 Registered: Dec-03
| Posted on Wednesday, April 14, 2004 - 08:46 pm: |
stereo separation stops around 250Hz, so there's no point to stereo subs as opposed to both being in mono. In fact, you want both in mono so they work completely together and move the same air at teh same time.. creating more bass. as for the type of enclosure.. try a ported box tuned low, around 30-35Hz.
Houston,
TX
Post Number: 4 Registered: Apr-04
| Posted on Thursday, April 15, 2004 - 08:40 am: |
Cool I did not know about the 250hz limit on Stereo seperation, now it makes sense. Thanks Glass |
NorthWest,
Michigan
Post Number: 1900 Registered: Dec-03
| Posted on Thursday, April 15, 2004 - 10:58 am: |
'bass' is pretty much monoral, yeah.
