Home > Message Board > Car Audio > Head Units > Archive through October 02, 2005 > Good or Bad? excelon x889 and preamps
Author Thread: Good or Bad? excelon x889 and preamps
Kf9627
im shopping for a new hu and i was wondering if the kenwood excelon x889 is as good as the tech specs say?also is there any disadvantages to having 5v preamps
Username: Illuminator
Post Number: 1854
If your amp can't handle the 5v outputs, you could have clipping issues, most of the time it won't be that big of a deal because it's only a 1v difference. You can get a dual-ganged potentiometer if you really need to turn the voltage down...otherwise I would avoid Kenwood. They never last for more than two years, if even that depending on use.
Home > Message Board > Car Audio > Head Units > Archive through October 02, 2005 > Good or Bad? excelon x889 and preamps [ « Previous ] [ Next » ]
