Thread: Bus in - ipod in? |
New member Username: Ozmodiarx
Post Number: 9 Registered: Sep-05
| Posted on Wednesday, September 28, 2005 - 01:37 am: |
On my deck there is a rca in 'Bus in' for like a cd changer, can i just plug my ipod into it using like a y splitter. I know there is a bus in controler, but i just want to ignore that. Will the bus in work as like a aux in or line in thing? |
Post Number: 10 Registered: Sep-05
| Posted on Wednesday, September 28, 2005 - 02:23 pm: |
anyone? |
Gold Member Username: Illuminator
Post Number: 1803 Registered: Apr-05
| Posted on Wednesday, September 28, 2005 - 06:35 pm: |
It's a Sony, isn't it? I believe it can only be used in conjunction with a CD changer, i'm not entirely sure. I do know, however, that it won't work with an iPod... |
Bronze Member Username: Ozmodiarx
Post Number: 11 Registered: Sep-05
| Posted on Thursday, September 29, 2005 - 02:17 am: |
will it hurt anything if i put my ipod into it? |
Post Number: 1822 Registered: Apr-05
| Posted on Thursday, September 29, 2005 - 02:42 am: |
Nope, you're free to try. |
