Thread: I desperately need help |
Unregistered guest |
| Posted on Monday, September 26, 2005 - 04:53 pm: |
Please anybody help me I recently got a new battery and my husband didnt have the connection wires tightened so the battery was dead he tightened the wires and now my stereo dont work. Its a jvc cd player and it just keeps flasing TEL no sound will come through at all. Everything works like it would normally just no sound. Please help i dont have a manual |
Gold Member Username: Illuminator
Post Number: 1763 Registered: Apr-05
| Posted on Monday, September 26, 2005 - 05:55 pm: |
'TEL' means the unit has been muted by the muting wire in the back of the unit. You most likely have 12v going to it. Completely disconnect the mute wire and never hook it up to anything again. |
| Posted on Monday, September 26, 2005 - 08:39 pm: |
Hey Jexx thanks for the information my husband said hes never heard of a mute wire. So im stereo illerate can u tell me how to go about doing that if you would if not cool ill figure it out. Thanks anyways |
| Posted on Monday, September 26, 2005 - 08:41 pm: |
thanks for your help can u tell me how to go about doing that please!!!!!!!!! |
| Posted on Monday, September 26, 2005 - 08:47 pm: |
what is the muting wire look like |
Post Number: 1775 Registered: Apr-05
| Posted on Monday, September 26, 2005 - 09:33 pm: |
Sorry about that, apparently the link to get to this forum is down (I have it bookmarked, heh). Yeah, the mute wire can be hooked up to a special type of cell phone so when you recieve or make a call, the stereo automatically mutes itself. I believe it is the solid brown wire... |
| Posted on Monday, September 26, 2005 - 10:54 pm: |
ok im lost what does my problem have to do with a cell phone just asking. ha ha so ill i have to do is disconnect the brown wire from where the back of the head unit! Remember im stereo illerate just want my music back! haha |
| Posted on Monday, September 26, 2005 - 10:58 pm: |
ok i went to get in my car and it was dead and yesterday we just put a new battery in the car and the stereo worked fine up in till this morning i went to get in the car and it would not do anything so my husband jiggled the cord to the battery and all of the sudden the car started but the stereo quit and all it will do is flash TEL and there is no sound. |
Post Number: 1781 Registered: Apr-05
| Posted on Tuesday, September 27, 2005 - 12:53 am: |
How is it wired? It sounds like a bad installation...heh. |
| Posted on Tuesday, September 27, 2005 - 07:53 am: |
i dont know it was already hooked up when we got the car. i just need your help on how to fix the problem. please!! |
Post Number: 1782 Registered: Apr-05
| Posted on Tuesday, September 27, 2005 - 09:09 am: |
Did you have any luck finding the 'TEL' (muting) wire? |
Nick_SQ Unregistered guest |
| Posted on Tuesday, September 27, 2005 - 01:39 pm: |
Telephone mute lead is usually brown, and from my past experiences it needs to be grounded, not wired positive (as far as i can remember) Or it could be a security thing in the deck...try resetting the unit with a pin (if it has a tiny reset button) |
Post Number: 1784 Registered: Apr-05
| Posted on Tuesday, September 27, 2005 - 03:36 pm: |
It doesn't need to be hooked up at all, does it? |
| Posted on Tuesday, September 27, 2005 - 03:43 pm: |
no it doesnt have a brown wire and it doesnt have a reset button |
Post Number: 1786 Registered: Apr-05
| Posted on Tuesday, September 27, 2005 - 03:49 pm: |
Does your unit have any wires not listed in the above picture? If it does, please list their colors... The mute wire might be a different color... Also, what is the brand and model number on your unit? |
its an old head unit its a jvc model kd-s570 if that helps any i dont have the manual or anything i cant find a damn thing on it. Im so damn lost here. Cant figure out the problem i guess ill just junk it. |
| Posted on Tuesday, September 27, 2005 - 10:43 pm: |
i just unhooked the damn thing and it started working again thanks for all your help!!!!really appreciated it very much. |
Post Number: 1797 Registered: Apr-05
| Posted on Tuesday, September 27, 2005 - 11:15 pm: |
Sorry I couldn't be of more help. |
| Posted on Wednesday, September 28, 2005 - 12:27 am: |
no problem you did what you could! Your cool for taking the time to even help me! thanks |
| Posted on Saturday, October 15, 2005 - 02:04 pm: |
how can i set the time?I'm lost..help |
