Thread: Ipod on Sony CDX-F7705X |
New member Username: Luisvalera
Post Number: 1 Registered: Sep-05
| Posted on Monday, September 26, 2005 - 11:34 am: |
Hi, I would like to know if there is a way of connecting an IPOD on this Head Unit, thanks. |
Gold Member Username: Illuminator
Post Number: 1776 Registered: Apr-05
| Posted on Monday, September 26, 2005 - 09:35 pm: |
Yeah, you can hook up an iPod using the RCA aux-in feature. Though there might also be an adaptor that allows you to control and charge your iPod through the stereo cd-changer port. |
Silver Member Username: Xdrummer03
Tenessee
Post Number: 125 Registered: Jul-05
| Posted on Thursday, October 06, 2005 - 10:51 pm: |
There a cable that best buy carries called a Deson (spell check) ice link that will change your changer controls into a ipod controller.Cable there runs 199.99.You can also do the new blue tooth setup in your car for 179.99. |
Unregistered guest |
| Posted on Tuesday, October 18, 2005 - 11:23 pm: |
crutchfield has a new interface for 99.99 it allows you to see the tracks on the head unit. |
