Thread: NEWBIE question: how do i install this used head unit |
New member Username: Zobsky
Dallas,
Tx
Post Number: 1 Registered: Sep-05
| Posted on Saturday, September 24, 2005 - 12:12 pm: |
Hi, I bought a used eclipse CD3424 off ebay with an intent to install in a 98 BMW 3 series car. reading through the supplied manual, there are mentions of mounting brackets and front bezels which I can't find in the shipment. Question: do I need these for my particular car and if so, where can I buy them? Thanks, Vin |
Dallas,
Tx
Post Number: 2 Registered: Sep-05
| Posted on Saturday, September 24, 2005 - 12:14 pm: |
PS. I'll be getting the harnass next week, this post mainly pertains to the physical installation in the console |
Gold Member Username: Illuminator
Post Number: 1711 Registered: Apr-05
| Posted on Saturday, September 24, 2005 - 02:08 pm: |
Yeah...you'll definitely be needing the mounting brackets... What mounting accessories did you receive? The trim ring, the mounting cage, the screws/clips for the mounting cage? |
Bronze Member Username: Jundi
Post Number: 20 Registered: Dec-04
| Posted on Saturday, September 24, 2005 - 02:21 pm: |
you probably need a dash kit and antenna adapter too |
Dallas,
Tx
Post Number: 3 Registered: Sep-05
| Posted on Saturday, September 24, 2005 - 07:04 pm: |
hi, got no mounting accessories where can i usually pick these items up from? thanks, vin |
Post Number: 1721 Registered: Apr-05
| Posted on Saturday, September 24, 2005 - 07:26 pm: |
Ebay would be my first suggestion. Some car audio shops might carry them as well. |
