Home > Message Board > Car Audio > Head Units > Archive through October 02, 2005 > Ford Mustang Mach System Bypass
Author Thread: Ford Mustang Mach System Bypass
Im about to bypass the two amps for the mach systems in a ford mustang, i think its a 93-97 model. as far as i know theres an amp for the fronts and an amp for the rears, do i need to do anything to prep this car? do i even need to bypass the amps or should i just remove them? i figured i would just run new wire from a new head unit to the fronts and rear speakers
Home > Message Board > Car Audio > Head Units > Archive through October 02, 2005 > Ford Mustang Mach System Bypass [ « Previous ] [ Next » ]
