Thread: Pioneer or Alpine? |
| Posted on Monday, September 12, 2005 - 05:00 pm: |
Which head unit is better: Pioneer p7700mp or Alpine 9828RB? I found the Pioneer 249€ and the Alpine 240€. |
Gold Member Username: Basshead86
Ocala,
FL
Post Number: 1040 Registered: Aug-05
| Posted on Monday, September 12, 2005 - 08:43 pm: |
if you are in the UK, check out www.caraudiodiscount.com really cheap prices. i would go with the pioneer, it has more features, and the features are more in-depth. they both have the same wattage per channel and # of preouts. pick whichever one you like more. |
| Posted on Wednesday, September 14, 2005 - 04:49 pm: |
Do you know the wattage in rms that these two units have per channel? -I'm from Greece- |
Ocala,
FL
Post Number: 1132 Registered: Aug-05
| Posted on Wednesday, September 14, 2005 - 09:29 pm: |
22wRMS per channel on the Pioneer, and i'm sure the Alpine ahs the same wattage |
| Posted on Thursday, September 15, 2005 - 08:49 pm: |
22wrms? Are you sure? I think it's too much. In a test (in a magazine) whith previous pioneer head units(3600,5600,6600,7600,8600,9600,p80mp), the more powerful HU was the p80 mp 4x60w which gave out 4x17,8 wrms. All the others were around 4x14 and 4x15wrms. I also search trough the internet and the most powerful HU i found is Alpine CDA-7893R (4x22,1wrms). |
