Thread: 2001 Nissan Xterra 6 disc changer Error 3 |
New member Username: Ctlesiak
Post Number: 1 Registered: Sep-05
| Posted on Sunday, September 04, 2005 - 10:29 pm: |
Can anyone help me out? I have a 2001 Xterra with a 6 disc changer. I tried to shuffle between discs and nothing would play or eject. It would read ERR 3. |
Relevant Product Info
New member Username: Jeffncqx4
Post Number: 5 Registered: Feb-06
| Posted on Wednesday, February 15, 2006 - 09:36 am: |
see the first 2 forums above for more help |
New member Username: T0n3dawgg
Post Number: 4 Registered: Jul-06
| Posted on Wednesday, September 13, 2006 - 04:02 pm: |
Hi, i'm having the same problem it just happened today when I turned on my car and switched the cd's from cd 4 to cd 3. It gave me a err 3 as well. I was wondering were you ever able to fix it. |
Bronze Member Username: Nospam4cj
Wichita,
Kansas
Post Number: 13 Registered: Sep-06
| Posted on Wednesday, September 27, 2006 - 02:07 pm: |
You may want to see the following to see how Nissan and Clarion are handling this problem. http://forum.ecoustics.com/cgi-bin/bbs/show.pl?4/137782 |
New member Username: Steveacordtx
Post Number: 1 Registered: Jan-07
| Posted on Wednesday, January 03, 2007 - 02:42 pm: |
I've got a Nissan Pathfinder 02. My error message is cd err FO. I haven't seen this error message on any of the above posts. It does the same clicking sound as described above. I'm going batty without cd's. I gave it to a audio repair guy that supposedly fixed it. I drove two hours to pick it up, and it still doesn't work. The only change from before is that it says DISC CHECK, only to return to CD ERR FO. Help!! |
