Home > Message Board > Car Audio > Head Units > Archive through September 10, 2005 > Need URGENT help wiring head unit
Author Thread: Need URGENT help wiring head unit
POD-Man
I removed an old panasonic tape unit from my International model truck and there were 6 green wires and one white leading to the unit my new head unit has a red, yellow, blue and black adapter (which doesnt fit) and also a 4 dbl wire (white, green, grey, purple) adapter for speakers. Where do the green wires and white wire from the dashboard fit to my new unit??? Any help greatly appreciated.
Relevant Product Info
Username: Pikesh
Post Number: 154
if there is really NO DIFFerence that one can tell between those green wire then i guess take it to professional... or if u can even distinguish between those green wires then msg back cuz i think there is a site that gives color codes of all the unit wires depending on car
Username: Spanky34
IL
Post Number: 22
yeah my pontiac had like 4 green wires, and like 3 red ones. It sucked, and it was just the most stupid thing i have ever seen. I just took it to a pro and had it done, mine was only 55 bucks. I will never again cut off a wiring harness :-(
Username: Pikesh
Post Number: 158
lol well yeah thats another option
Home > Message Board > Car Audio > Head Units > Archive through September 10, 2005 > Need URGENT help wiring head unit [ « Previous ] [ Next » ]
