Thread: Town & Country audio system |
| Posted on Thursday, April 01, 2004 - 09:03 pm: |
Does anyone know if it'd be worth it to use the factory amplifiers on some aftermarket speakers? As you all know, this particular van uses 4 amplifiers, bolted to the magnet of the speakers. I'd use a pair of 6x9's for the rear side-panel and some 5x7 mid's for the front doors. I get good sound now, but a little exrta mid and bottom end would be nice. Any other idea's would be good too. Thanks in advance. |
NorthWest,
Michigan
Post Number: 1665 Registered: Dec-03
| Posted on Friday, April 02, 2004 - 11:39 am: |
with that infinity self-amplified system, you need to replace all of the speakers, and the head unit in order to upgrade the system and have it sound remotely good.
