Thread: Advice needed on front door speakers for 96Tahoe!!!!(pics) |
New member Username: Mrmoe75
Post Number: 4 Registered: Aug-05
| Posted on Saturday, August 20, 2005 - 06:05 pm: |
I wanted advice on front door speakers. Has anyone ever heard of Infinity (6012I) 6-1/2" Loudspeaker, they have a rotating tweeter ensures proper imaging, so even if the speaker is mounted down low in the door, the soundstage can be brought up and optimized for the listener's location. Should I go with something like this or would a component be better. Also I wanted to put a pair of 6x9's in a dual enclosure. Here is picture of 6.5's. |
| Posted on Sunday, August 21, 2005 - 04:35 am: |
Components without a doubt. I got a 1997 Tahoe, and alls you gotta do it put the fade to the back and hear the difference in Coaxiles, and Components. |
Bronze Member Username: Justababyboy
Philly,
PA
Post Number: 36 Registered: Jun-05
| Posted on Wednesday, August 24, 2005 - 11:06 am: |
definately go with some components...preferrably infinity perfects....diamond audio....re xxx....or i personally like boston acoustics also |
