Thread: 3-way component system |
Silver Member Username: Redrange
Mo Hill,
California
Post Number: 231 Registered: Apr-05
| Posted on Friday, August 19, 2005 - 03:31 pm: |
Im looking into getting a 3-way component setup around $600 whether it on ebay or off a reatil site...At first i was looking at the focal 3 way and i heard them and like them, but i duno if i want to spend that kinda $ on the speakers...I have 2 atlas 12's sealed and i want something to blend well with them, any help is greatly appreciated |
Wisteria,
Lane
Post Number: 9291 Registered: Dec-03
| Posted on Friday, August 19, 2005 - 05:32 pm: |
in a range rover you could go three-way but for a good three-way set you're almost always talking over a grand. you could however, get a very good 2 way system for around $600 or less and do just about as well, and have a far easier time aligning the drivers for a good soundstage.
Mo Hill,
California
Post Number: 232 Registered: Apr-05
| Posted on Saturday, August 20, 2005 - 03:55 am: |
ok well i would have to wait another few weeks but if its worth it ill do it...i was guna spend around 1000 anyways for the focals should i just stick with those???if so wut should i get for the back just a set coax's? |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 747 Registered: Mar-05
| Posted on Saturday, August 20, 2005 - 05:21 am: |
Just get a decent midbass if you need rear fill. |
Bronze Member Username: Firlefanz
Post Number: 61 Registered: Jul-05
| Posted on Saturday, August 20, 2005 - 02:49 pm: |
As 2-way (active) system I might suggest: Scan speak 2904/ 60000 (you can get them with a nice aluminium housing), combined the with a Focal K3P only the 6,5 (not as a set). Or look at home-hifi drivers like excel, dynaudio and vifa (but mostly they dont fit in OEM spaces) if you want to built 3-way. |
