Thread: What does this mean? |
New member Username: Osito852
Post Number: 4 Registered: Aug-05
| Posted on Thursday, August 18, 2005 - 11:51 pm: |
Hi, I'm looking at a description of used 6x9 speakers and I quote "This is a used set with new grills. I could only check this on my home system. 1 of them popped @ 150w, the other took it. This will be a great set if you are not pushing over 100w. One did pop when pushed past the rating, but sounds great within limits. There is no physical damage to the speakers." So when he says popped the speakers, did he damage the speakers while he was testing them or whatever? Why is he recommending not to use the speakers over 100watts, RMS for these speakers is 100 watts anyways. . . Any other disadvantages / risks to buying a pair of used (or these speakers?) |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 745 Registered: Mar-05
| Posted on Friday, August 19, 2005 - 05:10 am: |
Stay away. Scratch 6X9 and get some 6.5's |
Post Number: 5 Registered: Aug-05
| Posted on Friday, August 19, 2005 - 08:19 am: |
I always had thought to get 6x9s if you have room for them, but do the 6.5's actually fit well in the space provided by 6/x9s for all cars?? |
Silver Member Username: Scubasteve
Annapolis,
MD
Post Number: 414 Registered: May-05
| Posted on Friday, August 19, 2005 - 10:03 am: |
They don't fit too well but its worth it to make them fit. Whatever you do, don't buy the 6x9s that "popped" |
Wisteria,
Lane
Post Number: 9282 Registered: Dec-03
| Posted on Friday, August 19, 2005 - 11:34 am: |
what he did was put too much power to the speakers without any sort of damping from an enclosure, causing the speaker to bottom out and go beyond it's Xsus. he basically blew the speaker by being a dumbass. buy something else. preferably new.
| Posted on Friday, August 19, 2005 - 12:30 pm: |
you can fit a component set consisting of a 5 1/2 and a tweeter if you build your own plate that way your 6x9s dont chew gum |
