Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Quetion about the whole "soundstage" ...
Author Thread: Quetion about the whole "soundstage" idea
a speaker ?
i know the whole idea is for it 2 be coming out in front of you...and having front components and no back speakers i how everyones system is set up...thats the "driver friendly" setup...
but honestly...if im running 2 12's in the trunk...and only components in the front...how will it sound in the back seat...??
Username: Basshead86
Ocala, FL
Post Number: 522
i run speakers in the back, and i think it sounds better, IMO, b/c i like rear fill.
Username: Jonathan_f
GA
Post Number: 4435
In the back seat it will more than likely sound muddy due to the subs being back there and the front seats blocking most of the sound of the front speakers. Not like you couldn't put some cheap coaxials off the head unit for any rear passengers if you're concerned about them.
Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Quetion about the whole "soundstage" ... [ « Previous ] [ Next » ]
