Thread: Car stereo speakers and live music |
| Posted on Thursday, August 18, 2005 - 07:38 pm: |
I collect live shows (mostly soundboard quality), and I'm upgrading my speaker system in my 2004 BMW 325i wagon. I recently installed a Kenwood EZ700SR receiver and with a budget of $1000-1500, what component speaker systems do you recommend to get that feeling of being at the show? Besides the speakers, do you recommend any other equipment? Thanks |
Gold Member Username: Jonathan_f
GA
Post Number: 4432 Registered: May-04
| Posted on Thursday, August 18, 2005 - 07:56 pm: |
Depends on what you want, do you want upfront "in your face" rock concert type of sound, or more of a smooth, jazz club characteristic? |
| Posted on Thursday, August 18, 2005 - 09:10 pm: |
"Smooth, jazz club" sounds about right. I mostly listen to blues, reggae and jazz. |
Wisteria,
Lane
Post Number: 9263 Registered: Dec-03
| Posted on Thursday, August 18, 2005 - 09:29 pm: |
dynaudio, rainbow, or similar for components, and use an amplifier for them. place them into fiberglassed kickpods for good imaging
| Posted on Thursday, August 18, 2005 - 10:35 pm: |
Do Focal speakers fall into the above catagory? Thanks for the response. |
GA
Post Number: 4433 Registered: May-04
| Posted on Thursday, August 18, 2005 - 11:20 pm: |
"Do Focal speakers fall into the above catagory? Thanks for the response" They're more forward. They're clean, but not as transparent as you'd get from Dynaudio, DLS, Morel, Rainbow, and similar sets. They can sound very good, but they're brighter, and lean more to punchy bass and an aggressive tweeter. |
