Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Rainbow Comps question
Author Thread: Rainbow Comps question
Username: Scab12886
Post Number: 148
i was lookin at rainbow 6.5 inch components at IQcaraudio.com and just had a quick question. i was wondering what the difference is between the CS 265 profi V, the CS 265 profi phase plug V, and the CS 265 kick V. they each have a different price and i don't know what the differences are between the 3 sets. if someone could explain it to me that would be great. also, one last thing...does anyone have any experience with this website? is it a good place to get rainbow comps or no? if not, where should i look? thanks in advance.
Username: Cdj
Southern Ohio
Post Number: 26
The Phase Plug version gives you a smoother, stronger mid-range.
The Kick Bass gives you more mid-bass punch, but are only good to 80Hz, MUST be used with a sub if you want to go below 80Hz.
Choice depends on what you want to accomplish.
Username: Firlefanz
Post Number: 59
Do you drive BMW E36?
Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Rainbow Comps question [ « Previous ] [ Next » ]
