Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Audiofiles-Acceptable Rear Fill
Author Thread: Audiofiles-Acceptable Rear Fill
Username: Mikechec9
Chicago/atlanta
Post Number: 705
I don't run rear drivers at all. but if i did, it would be like this (copy and paste the link):
http://www.carsound.com/UBB/ultimatebb.php?ubb=get_topic;f=5;t=001818
wondering what audiofiles thought.
Username: Jonathan_f
GA
Post Number: 4418
What, just simply with the rear fill wired out of phase on one channel?
Username: Glasswolf
Wisteria, Lane
Post Number: 9185
personally, if I used rear fill, I'd run them in mono, with a narrow bandpass filter.
that keeps the frequency range limited and prevents ruin of the front stage imaging.
Username: Mikechec9
Chicago/atlanta
Post Number: 716
i've never tried it. but it seems like if you did it and used midbass drivers with the narrow 2way filter like glass suggests, the result would be a delayed effect that succeeds the front image without upper frequencies.
kind of giving a true fill maintaining the forward imaging. does that sound about right?
Username: Glasswolf
Wisteria, Lane
Post Number: 9191
no delay.. but otherwise yeah you just get more midrange from the back to fill in.. without the highs to draw the soundstage back into the cabin of the car
Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Audiofiles-Acceptable Rear Fill [ « Previous ] [ Next » ]
