Thread: Have polk audio speakers... need some help! |
Bronze Member Username: Kdkd2020
Post Number: 28 Registered: Jul-05
| Posted on Saturday, August 13, 2005 - 09:52 pm: |
I just replaced my speakers with two 6X9 polk audio speakers in my front and two 6 1/2 polk audio components in my rear. I do not get the deep bass that i was looking for... should I get an amp.. and if so which one.. or should i replace them with some infinity reference speakers or what do u guys think?? cause i love bass and need it.... |
Post Number: 29 Registered: Jul-05
| Posted on Saturday, August 13, 2005 - 10:22 pm: |
anyone |
Silver Member Username: Jaackdeth
United States
Post Number: 535 Registered: Sep-04
| Posted on Saturday, August 13, 2005 - 10:35 pm: |
I would not go with Polk, I think you would have better luck with the Infinity series. And if your not using an amp, yes you will notice a difference. There are soooo many to choose, what is your budget? |
Post Number: 30 Registered: Jul-05
| Posted on Saturday, August 13, 2005 - 11:16 pm: |
under 250 |
Post Number: 31 Registered: Jul-05
| Posted on Sunday, August 14, 2005 - 03:43 pm: |
heres the thing.. im either gonna get just an amp to power the speakers... or get 1 12" sub with prolly 300-400rms and a mono amp just to power that sub. Should i do that.. or get an amp to power just the speakers??? I want bass |
United States
Post Number: 550 Registered: Sep-04
| Posted on Sunday, August 14, 2005 - 04:07 pm: |
Well if you want bass, and that's all you have for a budget, then I guess I would go with the sub, but it is not going to be well balanced out, as your HU doesn't have enough the put out like you want. If you added a 4 channel amp, doesn't have to be that great, you'd like that better! |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 733 Registered: Mar-05
| Posted on Sunday, August 14, 2005 - 08:38 pm: |
My first question is why do you have 6X9's in the front and 6.5 comps in the rear? If you have comps you will need an amp to power them properly. What kind of comps do you have? I have had just as much enjoyment out of Polk as I had out of Infinity. If you had a decent pair of coaxials up front power by the HU, and small sub powered with around 350w it would blend okay. However your best bet would be to wait and save up some more money so you could just buy better equipment all around. |
