Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Mixing 10 and 12 inch Subs?!
Author Thread: Mixing 10 and 12 inch Subs?!
Hey guys, i was wondering if i were to get a 10inch and a 12inch sub if it would sound good together or if it's just not good to mix them..? I listen to a lot of hard hitting songs and i
like quick, hard hitting power outta my subs but i also listen to a lot of rap, and would want a sub that could hit deep and hold the beat for a while. Im almost positive on gettin a 10inch image Dynamics, but if i was looking to add another sub later on, would this be a good idea?
Username: Scubasteve
Annapolis, MD
Post Number: 395
why not just get the 12" ID now? You can mix and match subs of different sizes but that would take a lot of planning and careful use of crossovers and EQs to do it right. Also, people choose not to use this approach because its unpleasing asthetically, especially if you only have one of each.
Username: Voodoochilde
Greencastle, Indiana
Post Number: 145
In short, no. When you mix subs that are so close in size they tend to sound unaccurate. You could probably get away with a 10 and a 15 or 18 if you set crossovers correctly but a 10 and 12 probably wouldnt work too well together.
Haha Alright.. that solved that problem quick. Ill stick with just the 10's,
Thanks guys.
Thanks guys.
Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Mixing 10 and 12 inch Subs?! [ « Previous ] [ Next » ]
