Thread: Speaker system with 2 type R's... |
speaker help Unregistered guest |
| Posted on Friday, August 12, 2005 - 12:26 pm: |
any suggestions on speakers and/or speaker pakages to go with these subs? head units? will i need a small amp for them? no car yet...so dont worry about fitting...i'll get w/e custom fitted if neccesary... no real price range either...but notin TOO insane for some speakers...a good amount of dif price ranges would help the most thanx alot ! you guys always give great help and ideas... |
Gold Member Username: Illuminator
Post Number: 1430 Registered: Apr-05
| Posted on Friday, August 12, 2005 - 02:30 pm: |
An external amp would make a great difference to whatever set of speakers you want to power, whether the amp is small or big as long as you are powering the speakers properly. Eclipse and Infinity Kappa components would sound nice with them, maybe even CDT if you have the money. For headunits, look into Eclipse, Alpine, Pioneer Premier, and Clarion ProAudio. Be sure that the headunit has Front and Subwoofer RCA outputs. |
