Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Hi!! Witch car alarm??
Author Thread: Hi!! Witch car alarm??
Username: Stefano
Rome
Italy
Hello!
I'm Stefano from Italy!
I'm interested to buy a car alarm but I don't know witch model or type...could you help me?
The requirement are:
1)It must close the door when I insert the alarm
2)It must close the window when I insert the alarm
3)It must have sensor onboard
4)It must have a powerful siren
5)It must to do the same chirp of the Bulldog car alarm, when I insert the alarm.
You can hear this chirp on this website http://www.bulldogsecurity.com/
here in Italy we haven't the alarm that does this sound when you arm or disarm the alarm... :-(
could you make me a list of the car alarm that have this chirp when you arm or disarm??? :D
thank you people, and sorry for my imperfect english.....
Stefano
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 76
I don't know about the chirp, but clifford has alarms that will do everything you want, and start the car on those cold italian nights, and mornings. Here is their web site. www.clifford.com
edster922
Jeremy,
What do you think of Clifford's entry-level model, the Arrow 5? Car-Toys has it for $250 installed.
thanks,
E.
Username: Erus37
Hollywood, Fl
IF YOU GET A CLIFFORD I SUGGEST THE MATRIX 3.5
RHODES COMPLETE AUTO RADIO IN HOLLYWOOD HAS FOR VERY CHEAP PRICE INSTALLED
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 100
All clifford alarms are well made. Just depends on what bells and whistles you want with it. As for 250 installed, that is about right for their low end alarms. I would go a little higher like mike said, but it is all up to what you want and what you want to spend.
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Hi!! Witch car alarm?? [ « Previous ] [ Next » ]
