Thread: Jl 1000/1 |
Bronze Member Username: Qcsfinest
Post Number: 47 Registered: Jun-05
| Posted on Wednesday, August 03, 2005 - 08:50 am: |
if the JL 1000/1 gives 1000 watts at 1.5-4ohms what does it do at 1 ohm? |
Wisteria,
Lane
Post Number: 8907 Registered: Dec-03
| Posted on Wednesday, August 03, 2005 - 08:54 am: |
goes into thermal protection mode, most likely.
Post Number: 48 Registered: Jun-05
| Posted on Wednesday, August 03, 2005 - 09:07 am: |
so they wont work at 1ohm? |
Wisteria,
Lane
Post Number: 8912 Registered: Dec-03
| Posted on Wednesday, August 03, 2005 - 09:19 am: |
they are not rated stable at 1 ohm. no.
Post Number: 49 Registered: Jun-05
| Posted on Wednesday, August 03, 2005 - 09:24 am: |
ok thanks....one last question, what kinda wiring options does jl give with there w6v2. Does it just come in 2 and 4 ohm? |
Wisteria,
Lane
Post Number: 8913 Registered: Dec-03
| Posted on Wednesday, August 03, 2005 - 11:32 am: |
www.jlaudio.com
Bronze Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 74 Registered: Jun-05
| Posted on Wednesday, August 03, 2005 - 04:29 pm: |
it comes in dual 2, 4, and 6 ohms I believe. |
Bronze Member Username: Ucfsaxman
Oviedo/orlando,
Fl
Post Number: 80 Registered: May-05
| Posted on Wednesday, August 03, 2005 - 05:38 pm: |
the w6v2 is dual 4 ohm only. |
