Thread: Another Amp Question |
The F--150 Guy Unregistered guest |
| Posted on Wednesday, August 03, 2005 - 02:09 am: |
know most of you are tired of seeing the same old post over and over, but I need a little help LoL. I just bought a 12in L7 2ohm and I have a kenwood 2 channel amp. I just want the biggest bang from what I have. I hooked it up in parallel and it was pure thunder, but unstable cutting in an out. Now I have it wired in a series and its sounds like its just not getting enough power. Its a small amp but when wired in parallel it was off the hook. |
The F-150 Guy Unregistered guest |
| Posted on Wednesday, August 03, 2005 - 02:14 am: |
I just read my post and I really dont get it myself. I really dont know to much about wiring options v/s 2ohm-4ohm. My L7 is a 2ohm and my little K-wood amp is not stable at 2ohm bridged. Do I have to wire it in a series? Do I just need to get more power/Bigger Amp? |
Wisteria,
Lane
Post Number: 8906 Registered: Dec-03
| Posted on Wednesday, August 03, 2005 - 08:53 am: |
Does the sub have dual 2 ohm coils? just the one sub?
| Posted on Wednesday, August 03, 2005 - 12:25 pm: |
Yes |
Silver Member Username: Jaackdeth
United States
Post Number: 368 Registered: Sep-04
| Posted on Wednesday, August 03, 2005 - 01:17 pm: |
The only thing you can get is either 1 ohm, or 4 ohms. What model is that amp? And take a look at this site, it shows differnt wiring options that you have. http://www.jlaudio.com/tutorials/wiring/index.html |
