Thread: Meta alarm |
New member Username: Dukedog
Post Number: 1 Registered: Mar-04
| Posted on Thursday, March 25, 2004 - 03:45 am: |
Can anyboby help me. Ive got a meta m357 bike alarm that i want to fit to my bike but i dont have any manuals, i need help with the installation. Thanks |
Unregistered guest |
| Posted on Wednesday, May 26, 2004 - 06:06 pm: |
If you still need info on fitting the 357 I can help. |
| Posted on Thursday, September 09, 2004 - 02:21 pm: |
I have purchased a Meta M357 alarm and have no wiring instructions can anyone help me please |
| Posted on Monday, December 20, 2004 - 03:36 am: |
I have an R1 witha Meta M351 fitted and I have just had the bike shipped out to Cyprus. The battery was disconnected for the journey and on re-connection I have no beeping from the alarm and the red LED does not flash in the same way as it did. It comes on but flickers but does not flash. I have put my Optimeter on and it shows the battery as being charged and yet the alarm still doesn't function and therfore I Cannot get the bike started. Can anyone help or suggest anythig please? |
New member Username: Trany
Post Number: 1 Registered: Dec-04
| Posted on Monday, December 27, 2004 - 07:07 pm: |
hi i have got a meta 357 alarm just going for a rip today when the alarm would not swich off so i could not start the think fitted the key r/c with new battery with no luck the led flashing ok any one help me |
| Posted on Saturday, January 01, 2005 - 01:25 pm: |
Hi, I've just had my bike shipped to france after an unfortunate head on collision, but no it won't start because of the immobiliser! Nothing will come on at all and there is juice coming from the battery. Any ideas as I'm dying to get back on it |
New member Username: Valkeire
Dublin Ireland
Post Number: 1 Registered: Mar-05
| Posted on Monday, March 28, 2005 - 01:55 pm: |
Hi All, I'm in the same situation, bought a Meta 357 TH bike alarm on eBay and need the wiring instructions. Would be very grateful for any info on the wiring identifcation (the wiring numbers/letters are still on the end of the wires). TIA, valkeire. |
| Posted on Wednesday, May 04, 2005 - 10:32 am: |
I have got to dissconnect my battery to change over, I have the code for the alarm but do not know who to enter it, not sure if the alarm will reset itself when I put the new battery on. Any help please. |
| Posted on Sunday, June 26, 2005 - 04:53 pm: |
http://www.metasystem.co.uk/index.php/msy_eng_en/msyuk/motorcycle_area/operating _instructions this is site of mETA SECURITY |
Dublin Ireland
Post Number: 2 Registered: Mar-05
| Posted on Monday, July 04, 2005 - 04:55 pm: |
Hi Anonymous, Thanks for the info, but I am looking for the wiring instructions on how to fit the alarm to my bike. Valkeire |
