Home > Message Board > Car Audio > Speakers > Archive through July 24, 2005 > What is the difference b/w component ...
Author Thread: What is the difference b/w component and 3/2-way speakers??
Username: Tweek52
Not sure what to get for my front speakers, infinity kappa 6-1/2 2 way speakers or..... 6-1/2 component speakers with the tweeter thing, which would be better for me? Do i need an amp with one and not for the other? thanks
Username: Xdrummer03
Tenessee
Post Number: 20
You should put a amp on really both. you will get alot better sound from the tweeters. They will require a bigger amp though. Use a Dynamat Door Kit for the components,or speaker kit for just the 2-3way 6.5's.
Username: Glasswolf
Wisteria, Lane
Post Number: 8248
a 2 way speaker is more convenient to install.
a set of separates will yield better imaging and usually, better power handling due to the flexibility of positioning for the tweeter, and the use of an external crossover respectively.
Home > Message Board > Car Audio > Speakers > Archive through July 24, 2005 > What is the difference b/w component ... [ « Previous ] [ Next » ]
