Home > Message Board > Car Audio > Security Systems > Archive through June 01, 2006 > Viper and Clifford
Author Thread: Viper and Clifford
Username: Cklukas
Coeur d'Alene, ID
Post Number: 8
I want a top of the line car security system. Any suggestions on either Viper or Clifford would be greatly appreciated.
Username: Jeremyc
Germany
Post Number: 763
Actually both are great alarms. I perfer clifford, since I have been using them for years, and have never had a problem. Others really like viper. Either way you are getting a great peice of equipment.
I don't know what you want option wise, but I have the Clifford intelguard 750 with the intel start module, and really really love it.
www.clifford.com/g5/sec/default.asp#intelliguard750
www.clifford.com/g5/access/default.asp#intellistart
Username: Cklukas
Coeur d'Alene, ID
Post Number: 16
I was looking at the Avant Guard 5. Any info? Does it come with all the remote start necesities? Do I need to buy anything else other than the AG5 system to use the remote start?
Home > Message Board > Car Audio > Security Systems > Archive through June 01, 2006 > Viper and Clifford [ « Previous ] [ Next » ]
