Thread: Component crossover |
Bronze Member Username: Ucfsaxman
Oviedo/orlando,
Fl
Post Number: 41 Registered: May-05
| Posted on Sunday, July 17, 2005 - 01:03 pm: |
Where is a "cool" place or the usual place to put the crossover for component speakers for the front doors? |
Gold Member Username: Jonathan_f
GA
Post Number: 4279 Registered: May-04
| Posted on Sunday, July 17, 2005 - 02:25 pm: |
Try to keep them out of the doors. They need to be in a dry place that is away from other wiring, and as close to the speakers as possible optimally. Kick panel locations work well if the crossover will fit behind them. |
Bronze Member Username: Dr_sharp
Post Number: 66 Registered: Jun-05
| Posted on Sunday, July 17, 2005 - 04:16 pm: |
Some cars have interior pockets on the doors (for maps or books or whatever). This is where i've put mine in both cars and it works quite well. You can drill a small hole in the bottom of the pocket (out of sight) like 1/4" or 3/8" in diameter and get all three sets of wire through. Some crossovers are much larger than that though so it just depends on the size i guess. |
Wisteria,
Lane
Post Number: 8197 Registered: Dec-03
| Posted on Sunday, July 17, 2005 - 09:51 pm: |
best place is usually behind the plastic kick panel fascia below the dash board, in front of each front door, or up behind the dashboard tucked out of the way and wire tied there with plastic zip ties. that's out of the way and dry, and nobody is going to kick them, sit on them, or hit them.
New member Username: Blair
Brisbane,
Queensland
Australia
Post Number: 5 Registered: May-05
| Posted on Wednesday, July 20, 2005 - 08:39 am: |
so is having them in the boot near the amp not ideal? |
New member Username: Kyle_allen
Post Number: 10 Registered: Jun-05
| Posted on Wednesday, July 20, 2005 - 09:44 am: |
Would mounting them under my seats create any problems. I have no room in my kick panels, and my dash room is extremely limited. Thanks for the help. |
Wisteria,
Lane
Post Number: 8255 Registered: Dec-03
| Posted on Wednesday, July 20, 2005 - 12:25 pm: |
as long as nothing snags the wiring it should be ok.
