Home > Message Board > Car Audio > Speakers > Archive through July 24, 2005 > Kappa speakers
Author Thread: Kappa speakers
I have a 200w Pyle cd player, 2 5 1/4 rockford fosgate P152c speakers attached. Contemplating adding 2 kappa 692.5i 6x9's. Does this deck have enough power to run this? No sub is attached.
(it's in a fresh water boat)
Thanks, Randy
Username: Riebread77
Post Number: 292
i had mine running off of the deck...it sounded good, but sounds a lot better with an external amp...I also had a pioneer deck, i don't know much about the pyle decks, but it's sound quality probably isn't the best.
The highs will be clear, but the lows may not hit hard because you won't have enough power to get that cone moving...It will give it enough power however, it definately is one of those speakers that are better off with an amp.
Home > Message Board > Car Audio > Speakers > Archive through July 24, 2005 > Kappa speakers [ « Previous ] [ Next » ]
