Thread: Right Rear speaker not working |
Unregistered guest |
| Posted on Wednesday, July 13, 2005 - 01:50 pm: |
I just bought a new Lanzar VBD400MP cd player and I got everything hooked up and all speakers were working, but when I was listening to my music one of my rear speakers just stopped. I checked the wires and everything and their all fine. I also checked the speaker and its fine. Whats wrong? Just can't figure it out. |
Silver Member Username: Illuminator
Post Number: 908 Registered: Apr-05
| Posted on Wednesday, July 13, 2005 - 01:53 pm: |
Sounds like a problem with the headunit. Just out of curiousity, how much did you pay for it? |
| Posted on Wednesday, July 13, 2005 - 01:54 pm: |
Both my rear speakers are 6x9" California Bass C4 600 watt max, 300 watt rms if that helps... |
| Posted on Wednesday, July 13, 2005 - 01:55 pm: |
I paid 85 for it... |
| Posted on Wednesday, July 13, 2005 - 01:59 pm: |
If I never get it to work can I just dual hook it up to my left speaker jack along with my left speaker or will that cause problems? |
Post Number: 910 Registered: Apr-05
| Posted on Wednesday, July 13, 2005 - 02:15 pm: |
That wouldn't be a good idea, it would put too much strain on the headunit and cause both speakers to sound bad. Do you have an ebay account? |
| Posted on Wednesday, July 13, 2005 - 02:23 pm: |
I bought it off of ebay from a store. |
Post Number: 918 Registered: Apr-05
| Posted on Wednesday, July 13, 2005 - 05:00 pm: |
That's terrible! I can't believe they charged that much! Not to chastize you or anything, but I think it would be a good idea to buy used equipment rather than brand new from ebay as the savings are incredible. |
