Thread: Need help before buying speakers. |
New member Username: Romic00
Post Number: 1 Registered: Jul-05
| Posted on Tuesday, July 12, 2005 - 09:55 pm: |
Hi i have a 2003 dodge ram quad and i just got a new deck for it. now i want to get better sound. I was thinking either 2 speakers for the front doors or 1 or 2 10" subs under the rear seat. Which one would you go with. If i get the speakers i wonder if i can use my amp to power them. It's a 800w amp 2 channel? I was looking to get 2 6x9 pioneer speakers. Are they any good? Thx in advance |
Post Number: 2 Registered: Jul-05
| Posted on Wednesday, July 13, 2005 - 09:24 pm: |
anyone? |
Silver Member Username: Riebread77
Post Number: 282 Registered: Jun-05
| Posted on Wednesday, July 13, 2005 - 11:30 pm: |
If you have an amp...you should look for speakers that you could use with it because it will bring out a little more ooomph in your speakers. Can you give us the specs of the amp? |
Post Number: 3 Registered: Jul-05
| Posted on Saturday, July 16, 2005 - 06:55 pm: |
ok i found a set of speakers for my dodge ram truck. this is the link http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5789691816&category=58031 %26 they are pioneer at 40w rms for the front doors. My deck is rated at 4x 50w will that be to much power for the speakers? or it wil be ok. Also in the near future i will get an amp to power the speakers.Also does anyone if i can fit a 6 1/2 speaker on the rear doors. i currently have a 5 1/4 speraker. Last question is will a 4 way speaker rated at 80 w rms sound better/ louder then the ones at 40 rms. Thank you. |
Post Number: 4 Registered: Jul-05
| Posted on Saturday, July 16, 2005 - 08:45 pm: |
1 day left of bidding |
Wisteria,
Lane
Post Number: 8141 Registered: Dec-03
| Posted on Saturday, July 16, 2005 - 09:44 pm: |
use a good 2 way or 3 way speaker set in front 4 ways are pretty much a gimmick and not that good. what is the make and model pof your amp? what is its RMS power rating and at how many ohms? after the front speakers with an amp, I'd look at a sub with a second amp to round out the frequency range
Post Number: 5 Registered: Jul-05
| Posted on Sunday, July 17, 2005 - 03:49 am: |
are the new pioneer TS-A6961R 6x9 any good? i wana get those and put them in the front doors. |
Post Number: 7 Registered: Jul-05
| Posted on Sunday, July 17, 2005 - 12:03 pm: |
noone? |
Wisteria,
Lane
Post Number: 8174 Registered: Dec-03
| Posted on Sunday, July 17, 2005 - 12:06 pm: |
listen to a set and see if you like them. it's subjective.. you may like them, I may not.
Post Number: 8 Registered: Jul-05
| Posted on Sunday, July 17, 2005 - 12:45 pm: |
i can hook an amp to them right? |
Wisteria,
Lane
Post Number: 8183 Registered: Dec-03
| Posted on Sunday, July 17, 2005 - 12:56 pm: |
why not
