Home > Message Board > Car Audio > Speakers > Archive through July 24, 2005 > HELP Krackling speakers
Author Thread: HELP Krackling speakers
Ive got standard factory speakers, a jvc kd-lx100 reciever and the speakers have started to krakle when there is any bass and if the volume is turned up at all. What should i do?
Username: Riebread77
Post Number: 254
it could be a few things...
1.) CD's are getting scratched
2.) the speakers are just getting worn out and old (sign of old age and may need to retire if you get my drift)
3.) You blew your speakers.
Buy a brand new CD from a store(so you know it is clear as a bell) and put it in...if you still get crackling...try adjust your EQ on the headunit...if you've done those things...it's time to say c-ya to your factory speakers...if that is it, you can get decent 2-ways for $100 a pair...look into that.
Username: Carguy
Post Number: 3535
Check your speaker cone. It could be cracked.
Home > Message Board > Car Audio > Speakers > Archive through July 24, 2005 > HELP Krackling speakers [ « Previous ] [ Next » ]
