Thread: Rms and power |
Bronze Member Username: Qup2cit
Australia
Post Number: 42 Registered: May-05
| Posted on Monday, July 11, 2005 - 05:40 am: |
if a speakers rms is say 350watts and their rms is 100 watts, what would happen if say i put 160watts rms into them or would they work fine if not better than just giving them 100 watts rms |
Silver Member Username: Scubasteve
Annapolis,
MD
Post Number: 145 Registered: May-05
| Posted on Monday, July 11, 2005 - 08:15 pm: |
"if a speakers rms is say 350watts and their rms is 100 watts..." never heard of that before anyway, i've never seen a more confusing question asked on this forum. please clarify. |
Gold Member Username: Jonathan_f
GA
Post Number: 4256 Registered: May-04
| Posted on Monday, July 11, 2005 - 09:43 pm: |
He means a 350 watt peak rated speaker, with a true 100W RMS rating. The 100W RMS rating is thermal, meaning it can withstand the heat of 100 watts of power. Anything above that is risking it, but remember that a 100W RMS amplifiers is only going to produce it for a little while due to the dynamic nature of music. You'll rarely use all that power. That being said, if you're careful not to overdrive the speakers, a 160W RMS amplifier won't hurt a bit. |
Australia
Post Number: 43 Registered: May-05
| Posted on Monday, July 11, 2005 - 10:57 pm: |
thanks jonathan, i did mean peak power instead of rms. thanks |
Wisteria,
Lane
Post Number: 7937 Registered: Dec-03
| Posted on Monday, July 11, 2005 - 11:37 pm: |
RMS is continuous, or what your amplifier's RMS should not exceed with that speaker. the peak rating isn't that useful but it's a momentary rating, or how much the speaker can handle for a brief exposure without pretty much cooking. stick to continuous or RMS ratings for amps and speakers both
