Thread: Amp-speaker/sub together?? |
fishboy Unregistered guest |
| Posted on Sunday, July 10, 2005 - 09:44 pm: |
Hey, I have been thinking about adding an amp/sub to my stereo lately. I wanted to know what you guys think about getting a 4-channel amp, bridging two for a sub, and using the other two for my 6x9's. Ive heard a little from both sides. Thanks for any help |
Silver Member Username: Scubasteve
Annapolis,
MD
Post Number: 147 Registered: May-05
| Posted on Monday, July 11, 2005 - 08:22 pm: |
technically speaking, that would work fine. Are those 6x9's up front or in the rear? Assuming they're in the rear of your car, if you add power to rear speakers, your soundstage will suffer. Midrange sound isn't non-directional, therefore you want most of it produced by your front speakers. Another consideration is that A/B class amps are less efficient than D class subwoofer amps. |
| Posted on Tuesday, July 12, 2005 - 06:03 pm: |
Ya, my 6x9's are in the back, in the front ive got tiny 4x6's, the specs on them are 35 RMS and 75 Max, I dont think giving them much juice would really add much SQ, if I were to do that I would definately get another amp to power the sub, even bridged an amp that small wouldnt push much of a sub. |
Annapolis,
MD
Post Number: 154 Registered: May-05
| Posted on Wednesday, July 13, 2005 - 05:52 am: |
4x6s, thats unfortunate, you should consider kickpods up front. |
