Thread: Need high powered Coaxials.. |
coax or comp? Unregistered guest |
| Posted on Friday, July 08, 2005 - 10:07 pm: |
Does anyone know of some good 6.5 coaxials that can handle 100-150 watts RMS? I don't want components because they are a pain in the as*s to install, and my buddy has regular coaxials which sound great when he turns it up. Or could anyone point out components that are easy to install and will preform well. I listen to mostly metal, but I do dabble in other styles.I have around $200 USD to spend on these |
Bronze Member Username: Prankstar008
San Diego,
CA
Post Number: 45 Registered: Jun-05
| Posted on Saturday, July 09, 2005 - 02:39 am: |
I got some pioneers for $55 a pair that are coxial, but the tweeter comes out if you want to make them component. And after typing all that I realized that they handel 120W peak and not RMS so.....yea |
Silver Member Username: Riebread77
Post Number: 236 Registered: Jun-05
| Posted on Saturday, July 09, 2005 - 03:15 am: |
lol thanks for the info |
Post Number: 237 Registered: Jun-05
| Posted on Saturday, July 09, 2005 - 03:21 am: |
Kenwood KFC-1689ie...handles 100 w rms/200 w max...never heard them though...just recommending based on power handling...not many 6.5" 2-ways can handle 100 w rms |
comp or coax Unregistered guest |
| Posted on Saturday, July 09, 2005 - 12:02 pm: |
I just want something that is an easy drop in application. Does anyone know any 3-Ways that handle lots of power?\ Thanks for your recommendation |
Post Number: 243 Registered: Jun-05
| Posted on Sunday, July 10, 2005 - 09:51 pm: |
3-ways are in the same boat as 2-ways...they will both have the same power handling. |
Silver Member Username: Alias747
MN
Post Number: 420 Registered: Apr-05
| Posted on Monday, July 11, 2005 - 12:40 am: |
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13540 These handle quite a bit of power. |
Post Number: 245 Registered: Jun-05
| Posted on Monday, July 11, 2005 - 01:31 pm: |
Very insensitive speakers @ 85db. |
gpz1100 Unregistered guest |
| Posted on Friday, July 15, 2005 - 12:56 am: |
What difference does it make if the speaker is rated at 55 or 100 watts rms? So long as you're driving it with clean power, and there's no distortion, the chance of blowing the speaker is minimal. IE, you can run 55w rms speakers with a 100W amp. You may blow them at super loud volumes, but so long as common sense is exercised, you'll be fine. In fact, you'll have more headroom, run your amp cooler, etc... |
coax or comp Unregistered guest |
| Posted on Friday, July 15, 2005 - 06:32 am: |
Thats the reason to run them with an amp is so that they sound better at higher volumes. I want to be able to crank these things |
