Thread: Db6500 |
kklagge Unregistered guest |
| Posted on Wednesday, March 17, 2004 - 07:39 pm: |
Does anyone else who has this set of components notice that the tweeters are extremely harsh when turned to higher volumes? I assumed (my first mistake, I know) that with a silk/polymer tweeter this wouldn't happen. In my truck (the Polk's are in the wife's) I have Crystal components with a silk tweeter and those sound incredible and are nowhere near harsh, even at extreme volume levels. I'm thinking of ordering just a pair of Crystal tweeters to replace the Polk ones for her. Any enlightenment on this would be most helpful. |
Silver Member Username: Tbone
OK
United States
Post Number: 209 Registered: Feb-04
| Posted on Thursday, March 18, 2004 - 12:02 am: |
Have you played with different mounting schemes that may take some of the harshness out. Are the tweeters aimed directly at the listeners, if so, can you angle them, with a shim under the mounting flange on one side, to fire in a less direct path? This might help some. |
| Posted on Thursday, March 18, 2004 - 06:04 am: |
They are in the pillars of my wife's Xterra, angled a little away from the center of the vehicle, more towards the front. Wiring backwards wouldn't cause this problem, would it? There's no distortion just piercing on the ears when you turn them up louder (unlike my Polk system at home which sounds perfect no matter how loud it gets) |
OK
United States
Post Number: 213 Registered: Feb-04
| Posted on Thursday, March 18, 2004 - 02:11 pm: |
Yeah, try wiring them in-phase, maybe it will help. |
