Thread: What amp do i use??? Everyone has been telling me the wrong thing |
Bronze Member Username: Dtribe
Post Number: 18 Registered: Jun-05
| Posted on Thursday, June 23, 2005 - 05:32 pm: |
I need a amp for 4 kicker vr 10s that are dvc 4ohm so they cant be wired down to 1 ohm so basicaly I need a amp that is 1000 stable @ 2 ohms Lookin to spend around 7 or 800 |
Silver Member Username: Alias747
MN
Post Number: 305 Registered: Apr-05
| Posted on Thursday, June 23, 2005 - 05:42 pm: |
Well I don't know who told you that you could wire 4 DVC 4-ohm subs to 1 ohm, but obviously you cant. For 700 bucks you have quite a few options. If you want the best, get this: http://www.woofersetc.com/product.asp?0=490&1=491&3=327 Or for a little cheaper: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem%26%26item%3D7982441529& category=38638 That's if you want to spend that much and you want the best SQ you can get. |
Post Number: 19 Registered: Jun-05
| Posted on Thursday, June 23, 2005 - 05:57 pm: |
thanks that one last page didnt load What amplifire is it |
MN
Post Number: 306 Registered: Apr-05
| Posted on Thursday, June 23, 2005 - 07:11 pm: |
Go to ebay and search this number: 7982441529 It is the same amp, but cheaper, becuase it is on ebay. |
Bronze Member Username: Iowahawks19
Post Number: 21 Registered: Jun-05
| Posted on Thursday, June 23, 2005 - 07:14 pm: |
hey aymond aren't you underpowering your subs BARELY.. those kickers are each 300w rms so your looking at 1200watts/ but im sure they'll still run fine only underpowering each by 50watts no bid deal, infact it's probably better |
