Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > Capicitors?
Author Thread: Capicitors?
Username: Xbranman
Chattanooga, TN
United States
Post Number: 31
do they help at all?
Username: Alias747
MN
Post Number: 299
For dimming lights? Not a whole lot. If you have problems with dimming lights, your best bet is to get a HO alternator.
Username: Xbranman
Chattanooga, TN
United States
Post Number: 32
whats the point of them?
Username: Illuminator
Post Number: 670
To make money. They really aren't very useful.
Username: Solacedagony
New Jersey
US
Post Number: 507
Capacitors are used so that the voltage to your amp doesn't sag during large bass hits.
Capacitors don't replace getting a HO alternator. If your lights dim, that means you're not getting enough amps out of your alternator. A capacitor just compounds this problem by adding more load, you just don't see the lights dimming anymore.
Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > Capicitors? [ « Previous ] [ Next » ]
