Thread: What ap should i get? |
Bronze Member Username: Xbranman
Chattanooga,
TN
United States
Post Number: 25 Registered: May-05
| Posted on Tuesday, June 21, 2005 - 08:25 pm: |
HIFONICS BRUTUS BX1605D or Kicker KX850.2 the subs i have are 2 kicker solobaric L5's (600 rms each sub) |
Bronze Member Username: Dominirica012
Charlotte,
North Carolina
US
Post Number: 53 Registered: May-05
| Posted on Tuesday, June 21, 2005 - 09:29 pm: |
hifonics since the watts match up better althought the kicker is probably a higher quality amp |
Chris Brewer Unregistered guest |
| Posted on Tuesday, June 21, 2005 - 09:36 pm: |
I have a Kicker S12L7 dual 2 ohm which is 1500 max and 750 rms and I want to wire it down to 1 ohm but I can't find an amp that I think could do it. Any help? |
Chattanooga,
TN
United States
Post Number: 30 Registered: May-05
| Posted on Wednesday, June 22, 2005 - 12:54 am: |
will the ohm load match up ok with the hifonics? cuz the subs are a dual 2 ohm. |
