Thread: Lights dimming |
New member Username: Chinorican150
New york,
New york
Us
Post Number: 6 Registered: Jun-05
| Posted on Tuesday, June 21, 2005 - 10:47 am: |
Ok here's my problem .. I'm running two 15" alphasonik 800 series subs both running at 1800rms combined and the amp. Powering them is a 1800 rms alphasonik amp.. When a certain low note hits my light dim. I kno it could be the alternator. I have a 2farad cap with it will a higher farad cap do the job or must I have a rebuilt higher amp alternator? |
Silver Member Username: Illuminator
Post Number: 646 Registered: Apr-05
| Posted on Tuesday, June 21, 2005 - 10:48 am: |
Higher amp alt, simply put. |
Silver Member Username: Alias747
MN
Post Number: 276 Registered: Apr-05
| Posted on Tuesday, June 21, 2005 - 11:49 am: |
I am surprised you could run 1800 wrms on a stock alt as it is. Wow, how many amps is your alt now? My healights dim doing 600 wrms! |
New york,
New york
Us
Post Number: 8 Registered: Jun-05
| Posted on Tuesday, June 21, 2005 - 11:58 am: |
Not too sure wat amp is mines now but its running but it dims ... Well if there's any alternatives or any other ideas please respond thanx . For ur responses so far... Oh do you kno where I can find a higher amp alt. For a 02 chevy malibu or do I have to build one? |
Silver Member Username: Mikechec9
Chicago/atlanta
Post Number: 224 Registered: May-05
| Posted on Tuesday, June 21, 2005 - 12:11 pm: |
http://stores.ebay.com/Iraggi-Alternator-and-Electronics_W0QQssPageNameZVIStoreH eaderLinksQQtZkm? you would need to email dominic iraggi and ask him about your specific car. i don't see one beyond '01 for a malibu. i got the amputator w/lifetime warranty. most importantly, i don't think there is any reason for you to spend on a HO alternator w/just 1800 watts. i would upgrade my big 3 first. http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=5;t=007801 i'm pretty certain this will fix the problem for a bunch less (copy the whole link and paste it). |
