Thread: Budget amp for (1) RE 3X 12" (2 ohm stable mono) |
Silver Member Username: Tragedy
San Jose,
CA
Post Number: 281 Registered: Feb-05
| Posted on Tuesday, June 21, 2005 - 04:22 am: |
I really hate to downgrade from my Zapco 6.0x but for budget reasons and a new child expected i have to... however ive put far too much work to not continue my project... what amp do you suggest to push (1) RE 3x 12"? I put in a custom HO alternator for a high wattage application.. so i would like to a least get the 1600rms RE reconmends... and if the amp is overrated.. then maybe 1800-2000rms. I just want good clean middle of the road power. I relize i wont be winning any SQ comps now.. but hey i guess something is better than nothing.. $450 is probably my max.. brand names or amp class are not as much as a concern anymore.. please your help is appreciated.. (btw i need max power @ 2ohm.. i special ordered my RE 3X dual 4ohm) |
San Jose,
CA
Post Number: 282 Registered: Feb-05
| Posted on Tuesday, June 21, 2005 - 04:23 am: |
application is 2.1 cf ported to 28hz.. |
San Jose,
CA
Post Number: 284 Registered: Feb-05
| Posted on Tuesday, June 21, 2005 - 12:30 pm: |
bump |
Gold Member Username: Carguy
Post Number: 3349 Registered: Nov-04
| Posted on Tuesday, June 21, 2005 - 01:12 pm: |
TraGedy, read your post under subs. |
San Jose,
CA
Post Number: 285 Registered: Feb-05
| Posted on Wednesday, June 22, 2005 - 02:49 am: |
suggestions? -(Eclipse) DA7232 not much info but it does 2000rms @ 2ohm... (not sure if its 2x1000rms at 2ohm stereo) -(Memphis) 16-MCD1500 | Class D | 1x1500rms @ 2 ohm | 1% THD | SNR >100dB | 5V Input | 7.68"W x 2.4"H x 21.25"L (rated at 13.8v DC) -(Orion) 2500D | Class D | 1x1700rms @ 2 ohm | .9% THD | SNR > 80dB | DF > 50 | 5V Input | 10.5"W x 2.3"H x 27.2"L (rated at 13.8v DC)
San Jose,
CA
Post Number: 286 Registered: Feb-05
| Posted on Wednesday, June 22, 2005 - 02:51 am: |
someone also reconmended an MA Audio Class T amp.. anyone know anything about MA Audio? |
Post Number: 3357 Registered: Nov-04
| Posted on Wednesday, June 22, 2005 - 08:56 am: |
TraGedy, I'd go with Orion. Don't waste your money on Class T amps. It only looks good on paper. |
