Thread: Budget amp for (1) RE 3X 12" (2 ohm stable mono) |
Silver Member Username: Tragedy
San Jose,
CA
Post Number: 278 Registered: Feb-05
| Posted on Tuesday, June 21, 2005 - 04:20 am: |
I really hate to downgrade from my Zapco 6.0x but for budget reasons and a new child expected i have to... however ive put far too much work to not continue my project... what amp do you suggest to push (1) RE 3x 12"? I put in a custom HO alternator for a high wattage application.. so i would like to a least get the 1600rms RE reconmends... and if the amp is overrated.. then maybe 1800-2000rms. I just want good clean middle of the road power. I relize i wont be winning any SQ comps now.. but hey i guess something is better than nothing.. $450 is probably my max.. brand names or amp class are not as much as a concern anymore.. please your help is appreciated.. (btw i need max power @ 2ohm.. i special ordered my RE 3X dual 4ohm) |
San Jose,
CA
Post Number: 280 Registered: Feb-05
| Posted on Tuesday, June 21, 2005 - 04:21 am: |
application is 2.1 cf ported to 28hz.. |
sq junkie Unregistered guest |
| Posted on Tuesday, June 21, 2005 - 04:25 am: |
hifonics collosus. lol. Probably a decent PG theyre pretty affordable too. |
New member Username: Sq_junkie
Anchorage,
AK
US
Post Number: 2 Registered: Jun-05
| Posted on Tuesday, June 21, 2005 - 05:34 am: |
Here you go. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14912 |
San Jose,
CA
Post Number: 283 Registered: Feb-05
| Posted on Tuesday, June 21, 2005 - 12:29 pm: |
bump |
Gold Member Username: Carguy
Post Number: 3348 Registered: Nov-04
| Posted on Tuesday, June 21, 2005 - 01:10 pm: |
TraGedy, try these eBay items: No need to give up quality. 5782800330 5783360673 5782152998 5783082447 5783033876 5782855408 5783541247
San Jose,
CA
Post Number: 287 Registered: Feb-05
| Posted on Wednesday, June 22, 2005 - 02:52 am: |
-(Eclipse) DA7232 not much info but it does 2000rms @ 2ohm... (not sure if its 2x1000rms at 2ohm stereo) -(Memphis) 16-MCD1500 | Class D | 1x1500rms @ 2 ohm | 1% THD | SNR >100dB | 5V Input | 7.68"W x 2.4"H x 21.25"L (rated at 13.8v DC) -(Orion) 2500D | Class D | 1x1700rms @ 2 ohm | .9% THD | SNR > 80dB | DF > 50 | 5V Input | 10.5"W x 2.3"H x 27.2"L (rated at 13.8v DC) |
San Jose,
CA
Post Number: 288 Registered: Feb-05
| Posted on Wednesday, June 22, 2005 - 02:53 am: |
just was browsing and found these... any ideas.. the MA Audio.. i have no idea on them.. anyone |
Silver Member Username: Redrange
Mo Hill,
California
Post Number: 145 Registered: Apr-05
| Posted on Wednesday, June 22, 2005 - 03:45 am: |
forgot da link |
