Thread: Amp for 2 15" L7's |
New member Username: Bonnieman97
Post Number: 1 Registered: Jun-05
| Posted on Tuesday, June 21, 2005 - 04:10 am: |
I was looking into a Hifonics Brutus 2000 watt amp to push my two L7's and was wondering if that would be enough. Also i would like everybodys opinion on hifonics and if anyone has had any personal experience with hifonics please post |
New member Username: Jmacdadd
Holland,
MI
Post Number: 6 Registered: Oct-04
| Posted on Tuesday, June 21, 2005 - 09:17 pm: |
Your amp selection should be based on the ohm load you are going to run. The L7 Solobarics come in two versions.....dual 2ohm or dual 4ohm. The ohm load you will run is crucial to your amp selection. Hifonics used to be GREAT. I would buy old school amps over new gear any day. They are more stable, under rated and easily repaired! |
Bronze Member Username: Riebread77
Post Number: 14 Registered: Jun-05
| Posted on Wednesday, June 22, 2005 - 12:54 am: |
I had two 12" L7's...I upgrade to the top of the line Eclipse...I sold the subs and now I'm looking to get rid of the amp. It is a Rockford Fosgate Power 1501bd (rated @ 1650+ watts @ 2 ohms). Jeremy is right. If your subs are DVC 2 ohm, this amp would fit the bill. I used it for 3 months and has just been sitting around for a few months after I sold my car. If your interested, email me at riebread77@aol.com or just reply on this message board. |
Post Number: 3 Registered: Jun-05
| Posted on Friday, June 24, 2005 - 12:43 am: |
i have the DVC 4 ohm version of the 15 L7 |
