Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > 400 watt? HCCA 225??
Author Thread: 400 watt? HCCA 225??
Username: Monkey_man
Post Number: 177
I know this amp has recently been all over the forum lately. However, i want to know if this amp can push 400 watts or more into 2 ohms. I know the better the battery and cap the more power it produces. But, i do not plan on upgrading the battery or alternator. I just want to get a cap. With this in mind, will this amp produce 400 watts or more into 2 ohms?
-Thanks
Username: Carguy
Post Number: 3342
No, it'll give you maybe around 250w - 300w tops at 2ohms. It will give you 400w+ at 1ohm.
Post Number: 179
Ya but i can't wire my subs to ohm. Can I? I have two alpine type e's wit 250 watts at 4 ohms single voice coil.
killerzracing
probably not since there are 4ohm single voice coils 2 is most likely the lowest you could go
Username: Carguy
Post Number: 3370
You can get a 3rd 4ohm DVC sub and wire them all in parallel.
Post Number: 181
That's what i was thinking. But, my box i made is huge and takes up almost my whole trunk. So i made another post asking if 2 subs ported would be louder than 3 subs sealed.
Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > 400 watt? HCCA 225?? [ « Previous ] [ Next » ]
