Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > What impedence should i run for 2 typ...
Author Thread: What impedence should i run for 2 type R subs?
Username: Zagross
Post Number: 12
alright i have 2 alpine Type R 12" subs, they are duul 4ohm voice coils, so i will make each of them 2 ohm subs by bridging the 2 coils in parallel.
now i have 2 subs @ 2 ohms each, i have a 1500D hifonics brutus amp, i can run the amp @ 1 ohm if i hook the subs in parallel right? just making sure, since its my first install.
Username: Thrushdtd
New York
Post Number: 123
yes if you do that you will be fine/ Tell me how it sounds cuz i have 2 type r's and just baught a new amp but am still open for options.
Username: Alias747
MN
Post Number: 269
Watch the gain when you do that. If I am not mistaken, that amp does 1500wrms @ 1 ohm. Both of those subs together are 1000wrms if they are the '05 versions.
Username: Zagross
Post Number: 13
what should i put the gain at? i have no idea what gain is, is it like bass boost from the amp?
Username: Zagross
Post Number: 14
i got a deck with a 2.2V out and my 2 subs are type rs in parallel, and my amp is 1500D hifonics, what should my gain be around? i have no idea.
Username: Mikechec9
Chicago/atlanta
Post Number: 223
thats a perfect power for those subs (if '05). my repeated rule of thumb is rms+50%. so 1000watts plus 1/2=1500. like isaac said, set your gains.
(simplified) gain setting
turn gain all the way down on your amp.
set the HU to neutral
turn the HU up 75% or just before it starts to distort
turn the amp gain up till it starts to distort or reproduce unclean bass, then turn it down until it is clean.
Home > Message Board > Car Audio > Amplifiers > Archive through June 24, 2005 > What impedence should i run for 2 typ... [ « Previous ] [ Next » ]
