Thread: Wiring help |
Bronze Member Username: Buddyleee5
Post Number: 65 Registered: May-05
| Posted on Monday, June 20, 2005 - 05:40 pm: |
i have a ppi 1500.1 amplifier thats going to be powering 2 subs at 750 watts rms a piece on a 1-ohm load. What do i need to do to wire the amp. I have an alpine headunit with 2 volt preamp outputs for the subs. what am i going to need to wire this up and is there any where online that i can find this info? |
Silver Member Username: Alias747
MN
Post Number: 265 Registered: Apr-05
| Posted on Monday, June 20, 2005 - 06:03 pm: |
So I take it that amp puts out 1500 wrms @ 1 ohm? What is the impedance of your subs? Details bro, can't help unless we know what you have. |
Post Number: 66 Registered: May-05
| Posted on Monday, June 20, 2005 - 06:06 pm: |
yah 1500 wrms at 1 ohm and the subs are dual 4 ohm voice coils |
MN
Post Number: 266 Registered: Apr-05
| Posted on Monday, June 20, 2005 - 06:17 pm: |
Ok then wire the subs to the amp like this:
You will get a final impedance of 1 ohm. Just go to jlaudio.com and go to the tutorials if you want to see it for yourself. I am not sure what you were trying to ask about the preout voltage on you HU. You might want to re-word that. |
juan g6 Unregistered guest |
| Posted on Monday, June 20, 2005 - 07:09 pm: |
how do i install an amp for subs on a 2006 pontiac g6 with stock stereo |
Post Number: 67 Registered: May-05
| Posted on Monday, June 20, 2005 - 07:57 pm: |
no i understand how to wire the subs, that wasn't what i was looking for. I was wondering what i was going to need for wiring to wire the amp and how to wire it, or where to find the info on wiring it to the headunit/battery |
