Thread: CAN I RUN MY NEW JL SUB WITH MY OLD AMP |
New member Username: Twillis88
Boston,
MA
Post Number: 1 Registered: Jun-05
| Posted on Monday, June 20, 2005 - 09:00 am: |
I just bought a JL Audio 12" W6 v2 d4 Subwoofer. I have an Phoenix Gold OCTANE R5.0:1 MonoBlock Amplifier will this amp be able to power my new sub. The amp is 500 watts at 2ohms and 250 watts at 4ohms |
Silver Member Username: Mikechec9
Chicago/atlanta
Post Number: 204 Registered: May-05
| Posted on Monday, June 20, 2005 - 07:13 pm: |
yes. wire it at 2ohms, and it will work perfectly. http://www.jlaudio.com/tutorials/wiring/#2dvcsp |
Boston,
MA
Post Number: 2 Registered: Jun-05
| Posted on Wednesday, June 22, 2005 - 04:35 pm: |
Even though the subwoofer is 4 ohms I can still run the amp at 2 ohms |
Bronze Member Username: Zagross
Post Number: 16 Registered: Jun-05
| Posted on Wednesday, June 22, 2005 - 08:09 pm: |
na its dual voice coil, so connect the voice coils in parallel and it will be a 2 ohm sub. |
