Thread: Which amp for a W6? |
Bronze Member Username: Skaman272
Post Number: 37 Registered: Mar-05
| Posted on Sunday, June 19, 2005 - 07:40 pm: |
i'm in the market for a new amp for my 12" W6v2. I narrowed it down to a phoenix gold xenon amp. what i'm wondering is should i get the x400.1 or the x600.1 they have the same features as the JL slash amps, and cost alot less. I know the x400.1 will hit the rms of the sub prefect, but JL underrates their subs, will a x600.1 make a noticable difference without compromising SQ or reliability? |
| Posted on Tuesday, June 21, 2005 - 07:47 am: |
nah the 400.1 will be fine consider the alpine amps too (MRD-M501, MRD-M605 etc) and the JL E1400D e series amp
New member Username: Jmacdadd
Holland,
MI
Post Number: 5 Registered: Oct-04
| Posted on Tuesday, June 21, 2005 - 09:15 pm: |
I always go for more power than I need because you can run the amp at a lower gain and not push it so hard. Go big. Room for more power down the road if you want to get another sub or a bigger one! |
