Thread: Can Anyone Help Me? |
New member Username: Apriliaracer
Spokane,
WA
United States
Post Number: 1 Registered: Mar-04
| Posted on Thursday, March 11, 2004 - 08:20 pm: |
I recently bought a Ford Explorer which had a Pioneer head unit and Ford factory speakers. I took out the speakers and installed some Polk's that I had from my old car and it sounds absolutely horrible! I have never installed anything on my own before, so I don't know if possibly the wiring is wrong, or if I just need a new head unit or what? Any ideas? I get really bad low-end distortion on any remotely high volume, but my high-end sounds great. The wiring is done with electrical tape, no harness. Does this matter, and is the wiring just pos/neg or does one wire go to the tweeter and the other to the cone? Sorry for all the questions. Please help if you can! |
Silver Member Username: Tbone
OK
United States
Post Number: 141 Registered: Feb-04
| Posted on Thursday, March 11, 2004 - 11:06 pm: |
Are the polks seperates? If they are coaxials, there should be only one place for connection, not seperate ones for the tweeter and the cone. |
New member Username: Thespotlight
Amarillo,
TX
Post Number: 4 Registered: Mar-04
| Posted on Tuesday, March 16, 2004 - 10:09 pm: |
Maybe one of your speakers is hooked up backwards and is out of phase. |
